'91 mustang GT
joelab
Member - Posts: 7
Posted: October 23, 2005 at 12:55 AM / IP Logged
Hey i have a 1991 Ford Mustang GT and the previous owner ripped out the alarm before selling me the car.  The power door locks now no longer work and i'd like to get it hooked up to the alarm I have now.  Any ideas as to where the would have been spliced for the alarm so I can hook them up again?
Thanx Alot
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1990-91&make=Ford&model=Mustang&ID=17828&type=Alarm
redpeppers
Silver - Posts: 483
Posted: October 23, 2005 at 1:02 AM / IP Logged
sounds like they cut the lock and unlock wires and didnt wire them back up....what i would do is try to wire the factory stuff back up and see if it works then go from there...the wire colors r as goes
pink / YELLOW ...lock
pink/green...unlock
they r 5 wire door locks when adding aftermarket system to the mustang.  let me know if u need help with that.....
Where theres is a wire there's a way.
joelab
Member - Posts: 7
Posted: October 23, 2005 at 1:04 AM / IP Logged
perfect i'll check that out in the morning
thanx alot!!
redpeppers
Silver - Posts: 483
Posted: October 23, 2005 at 1:07 AM / IP Logged
np oh ya i forgot to tell u those wires r in the drivers kick panel.........
joelab
Member - Posts: 7
Posted: October 23, 2005 at 1:15 PM / IP Logged
ok heres the deal, i found the pink / YELLOW and pink/green in electrical tape... connected to nothing, i spent almost 2 hours trying to find the other end but no luck.  what i did find was a: red wire, red w/ black stripe, blue, blue w/white, blue w/black (5 wires? none of them connected, just electrical tape on the ends).  the red wires go up to the siren under my hood, and it appears the others are spliced into the giant mess of wires under the kick plate.  its a compustar 2wama-a that i have installed right now (cm3300 module).  By any chance are those all the wires i need to hook up the locks to my alarm?  and if so how? any help would be greatly appreciated.  thanx
Moderator - Posts: 12,488
Posted: October 24, 2005 at 9:12 AM / IP Logged
Do you know what system he had in there from before ? Also, what are the wire colors that are attached to the ends of the  PINK / YELLOW & PINK/GREEN wires ?
joelab
Member - Posts: 7
Posted: October 24, 2005 at 12:32 PM / IP Logged
Im not sure what system he had in there before.  and the pink / YELLOW and pink/green wires are just wrapped in electrical tape all the way up under the dash, im prety sure it leads to the switch.. not positive tho.  the b red wires that are going to the siren i assume were put there when i got the alarm installed.. i asked for them to hook up the power door locks for me but they coulnt find where the old alarm was spliced.  now that ive found the pink / YELLOW and pinmk/green i thouhgt maybe i could hook it up.
joelab
Member - Posts: 7
Posted: October 25, 2005 at 10:28 PM / IP Logged
any ideas?
mo12v
Posted: October 25, 2005 at 11:13 PM / IP Logged
Best thing to do is Hook ALL Factory wires back together.  Make sure EVERYTHING works and then Install your Compustar.............Who knows ...the location of where the mess is may not be the place you want to install your unit
MO
joelab
Member - Posts: 7
Posted: October 25, 2005 at 11:19 PM / IP Logged
well the unit is already installed.  its all working fine, just dont have the power door locks hooked up, and it looks like the place where i got it installed already ran the wires for the keyless, they just told me they couldnt find where the old alarm was spliced for the door locks so they couldnt hook it up, but i found those wires
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
