is this enough power ?
michael38127
Member - Posts: 19
Posted: October 25, 2005 at 10:56 PM / IP Logged
I have three rockford p3's and 1 T8002 i want to know if this is going to be enough power for all three of the subs
stevdart
Platinum - Posts: 5,816
Posted: October 26, 2005 at 8:16 AM / IP Logged
You need to loosen up the fingers and type more info in your question.  Box type and size, impedance load on the amp, amp's power output, vehicle....  And do you have this all hooked up yet or is it sitting in the garage waiting for someone to tell you it's okay to install?
michael38127
Member - Posts: 19
Posted: October 26, 2005 at 8:17 PM / IP Logged
15 inch
TypeWoofer
Voice coilConfiguration - Dual
Material - Aluminum
Description - 2.5"
Cone MaterialPoly/Plastic -
Parabolic Injection Molded Polypropylene
Frame MaterialFrame - Cast
Material - Aluminum
Surround Material
Spider
Crossover
SpecificationsPower handling(RMS) - 500 Watts
Power handling(Peak) - 1000 Watts
Impedance - 2 Ohms
Sensitivity - 88 db
Vas - 145
Fs - 22
Qts - .489
Xmax - 12.0
DimensionsDepth Bottom mount - 7.7 in.
Cutout - 13.79 in.
Displacement - 184.90 cu in.
Magnet weight - 102 oz.
EnclosureRecommended Sealed (Cubic Feet) - 2.0
Recommended Ported (Cubic feet) - 2.50 @ 33Hz
2
Per channel power
is this enough power ? -- posted image.
CEA-2006 compliant
125 W x 2 @ 4 Ohms RMS
250 W x 2 @ 2 Ohms RMS
400 W x 2 @ 1 Ohms RMS
500 W x 1 @ 4 Ohms Bridged RMS
800 W x 1 @ 2 Ohms Bridged RMS
Total power800 Watts
BridgeableYes
CrossoverHP 40-4kHz 24dB per Octave
LP 40-4kHz 24dB per Octave
Subsonic Filter 28Hz
Tone controlsBass Control
0 to 18 dB @ 35-70 Hz
Signal inputLow level -
Quantity - 1
Type - RCA(pr)
Line output1 RCA(pr)
Phase control
Power inputConnector - Block
Wire gauge - 1/0 AWG
Speaker outputBlock
Power supply topology
Output topology
Display
HeatsinkType -Cast
Cooling -Fan Cooled
Protection
Remote controlIncluded
Type - Wired
Controls - Bass
ClassA/B
Marine use
Specifications
Stereo/Mix mono
Frequency response20 to 20k Hz +/- .5 dB
Dimensions2.6 X 12.8 X 23 (inches)
