Theile Parameters for Infinity Reference
j_darling2007
Copper - Posts: 210
Posted: October 26, 2005 at 4:37 PM / IP Logged
I have looked alot of places (including infinity's website) for the thiele parameters for the 1242w reference series.  Does anyone have them or know where I can find them.
There are 3 kinds of people in the world, those who can count and those who can't
DYohn
Platinum - Posts: 10,741
Posted: October 26, 2005 at 10:36 PM / IP Logged
I checked as well and it appears Harmon has not published T/S parameters for this sub model.  You can write them and see if they can send the estimates to you.  Or, you can measure them yourself if you have the tools and time.
j_darling2007
Copper - Posts: 210
Posted: October 27, 2005 at 2:39 PM / IP Logged
Well, I am pretty sure I have the tools.  Is there a link for how to measure them.
DYohn
Posted: October 27, 2005 at 2:41 PM / IP Logged
This will get you the main ones for enclosure construction.  http://www.bcae1.com/spboxad3.htm
j_darling2007
Copper - Posts: 210
Posted: October 27, 2005 at 2:50 PM / IP Logged
I take that back, I don't have the tools.  Do you know of any other place I can look for the T/S Parameter.  I am going to be building a downfiring ported box on Sunday and Would like to have some time to play with WinISD before I start to build.
j_darling2007
Copper - Posts: 210
Posted: October 27, 2005 at 2:55 PM / IP Logged
Or, if someone has the specs for a ported box to build for this sub, i could just build the box.
DYohn
Posted: October 27, 2005 at 3:10 PM / IP Logged
That driver does not exist in the Thiele/Small driver database either.  You'll have to contact Infinity.  Suggested enclosure parameters should be included in the owner's manual for that speaker.
j_darling2007
Copper - Posts: 210
Posted: October 27, 2005 at 8:23 PM / IP Logged
I downloaded the owner's manual.  It only includes a few of the parameters.  Its not enough to design the box.  I e-mailed Infinity.  When they respond, I will be sure to post the parameters on here
Thank you for the help,
Jacob
j_darling2007
Copper - Posts: 210
Posted: October 28, 2005 at 9:48 PM / IP Logged
I just got the e-mail from infinity.  It says "Nominal Impedance: 2 or 8 ohms".  Then it says "Voice coil DC Resistance: 1.85 ohms".  Is something wrong here, because if the voice coils were 2 ohm, the nominal impedance would be 1 or 4 ohms, right.
I know that this is a dual 4 ohm subwoofer though
DYohn
Posted: October 28, 2005 at 11:19 PM / IP Logged
Voice coil impedence (Le) is different from voice coil DCR (Re).  "Nominal impedence" of 2 or 8 ohms would be correct for a 4-ohm DVC woofer.  DC resistance is a differnet factor.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
