Push button start with Matrix 10.5
tragik
Copper - Posts: 169
Posted: October 31, 2005 at 4:00 PM / IP Logged
be carefull using a latched output from the alarm. Alot of times, a latched output will reset once it senses power on the ignition. could cause problems. A latching relay is still your best bet.
Northstart.....or start it your damn self.
tragik
Copper - Posts: 169
Posted: October 31, 2005 at 4:06 PM / IP Logged
On that diagram that gives a 12V latched output from a momentary pulse, All you have to do is add one more relay to invert the polarity of the output.
87, ground
85, ground
86, 12v output from relay latch circuit
30, is your new negative latch output
Be sure to fuse everything accordingly
