sealed subwoofer
gsr.sedan
Posted: November 03, 2005 at 12:42 PM / IP Logged
I built a simple square box that's too large.  The ideal size was 1500 cubic inches and mine came out to be about 2500 cubic inches sealed subwoofer -- posted image.   The problem is that it bottoms out.  I was told that the large box doesn't give the cone enough back pressure.
Would adding more fiberglass fill help OR do I need to un-install and re-cut the box?
jstruckman
Copper - Posts: 465
Posted: November 03, 2005 at 12:48 PM / IP Logged
Just add material in the box until you get to the desired airspace you want.
Jazzy
DYohn
Platinum - Posts: 10,741
Posted: November 03, 2005 at 1:11 PM / IP Logged
No.  Adding fiber-fill to an enclosure will make it act as if it is larger, not smaller.  You need to either re-make the enclosure, or add solid material to the inside like 2X4's glued in place, or add extra bracing.
