need help with install
Am pM HooDluM
Member - Posts: 16
Posted: May 08, 2002 at 5:41 PM / IP Logged
need help with install with 91 Jeep Cherekee......battery on passenger side...and can't find a way through firewall.....anyone know where i can get through
NyxBass
Silver - Posts: 226
Posted: May 08, 2002 at 6:51 PM / IP Logged
If you really can't find a grommet, you can always drill. Make sure that there is nothing on either side you are drilling. Use a grommet so that the wire won't get cut goign through.
/NyxBass
Static Revenger
Member - Posts: 23
Posted: May 08, 2002 at 8:13 PM / IP Logged
There is a factory grommet or two on the firewall.Saddly though I don't think you will get a very big gauge power wire through it as it's already stuffed with all sorts of factory wiring.
So do as NyxBass suggested and drill you a hole.Use either a drill bit or a uni-bit taking your time as to make sure not to hit any other wires,vacum lines and such obstructions,then grommet it to protect the wire and to seal the hole from any possible moisture.
Am pM HooDluM
Member - Posts: 16
Posted: May 09, 2002 at 7:44 AM / IP Logged
thanks guys
Static Revenger
Member - Posts: 23
Posted: May 09, 2002 at 8:33 AM / IP Logged
No problem bro
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
