2001 Nissan Altima, alarm/remote start wiring
jcap
Member - Posts: 41
Posted: November 05, 2005 at 12:02 AM / IP Logged
need wiring diagram for 2001 nissan altima and hooking up door locks also
jcap
infinkc
Copper - Posts: 438
Posted: November 05, 2005 at 10:07 AM / IP Logged
12volts WHITE/ red    +   ignition harness
Starter BLACK / YELLOW    +   ignition harness
Second Starter BLACK/ blue    +   ignition harness
Ignition BLACK/ red    +   ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ pink    +   ignition harness
Second Accessory WHITE/ blue    +   ignition harness
Keysense
Power Lock gray    -   smart entrance control
Notes: The smart entrance control unit is located to the right of the steering column. It is black or blue in color.
Power Unlock purple    -   smart entrance control
Lock Motor RED / blue      smart entrance control
Unlock Motor yellow      smart entrance control
Parking Lights+ RED / blue      steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white    -   drivers kick panel or SECU
Notes: To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin red or RED / blue    -   light in trunk
Hood Pin pink/black    -   smart entrance control
Trunk/Hatch Release ORANGE / black    -   smart entrance control
Power Sliding Door
Factory Alarm Arm lt GREEN/ red    -   smart entrance control
Factory Alarm Disarm GREEN/ YELLOW    -   smart entrance control
Disarm No Unlock
Tachometer WHITE/ black      6 pin plug at distributor
Wait to start
Brake Wire RED / green    +   brake pedal switch
Parking Brake
Horn Trigger brown or grn/yel    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
