Remote Battery cutoff switch
tmpintnl
Posted: November 05, 2005 at 9:03 PM / IP Logged
Howdy - I am trying to sort out a remote battery cutoff switch that can be operated via a remote keyless entry with auxiliary channels.  I have a solenoid-style switch that interrupts main power when one of the switching terminals is grounded.  The standard installation uses a small toggle switch to connect to ground to switch power off.  I would like to use a negative pulse from a remote keyless entry to do this, rather than a switch.  I am assuming that I need to use a latching relay to set ground with one pulse, and open with another pulse.  The problem is that I don't know very much about latching relays and how they are operated.  I am looking at Magnecraft relays.  Do I need to use a dual coil 12V latching relay, or a single coil?  How would the wiring diagram look for this application?  I would like it to operate both "ON" and "OFF" with a pulse from the same source (to use only one channel), but could use two channels if necessary.  Thank you so much!
Toby Peterson
tragik
Copper - Posts: 169
Posted: November 06, 2005 at 10:50 PM / IP Logged
https://www.the12volt.com/relays/page5.asp
You can make a latch out of standard bosch relays and diodes using one of the diagrams on here.
Northstart.....or start it your damn self.
tmpintnl
Posted: November 06, 2005 at 11:11 PM / IP Logged
Tragik - I tried to put one of these assemblies together, and could not get it to latch properly.  I was not able to see what I had done incorrectly, but nevertheless could not get it to function as desired.  The other issue with this arrangement is that the relay set is quite bulky, which is an issue in my application with very little spare room in the relay compartment.  I think that I need to go with an "official" latching relay, which is why I posted my question.  I don't have enough knowledge of these devices to determine what style to use, and how it should get wired up to my solenoid battery cutoff switch.  Thanks for the input, however.
Toby Peterson
Ween
Platinum - Posts: 1,368
Posted: November 07, 2005 at 10:42 AM / IP Logged
hi,
you may look into this post....
https://www.the12volt.com/installbay/forum_posts.asp?tid=57075&KW=ween
using the VW relay may work fine for you, as it is less than 1.5" cube.
you'd need to test the requirements for the coil current though, not sure how much the keyless entry output you have supplies
hope this helps
mark
joe_1
Silver - Posts: 286
Posted: November 12, 2005 at 4:10 PM / IP Logged
if you are wanting to make a remote battery cut off, what is it going to be turning off? i take it not the power to all the vehicle as you would not be able to turn it back on with no power going to the alarm, for your remote to work.
i am also a technician so if you have any engine trouble let me know, and i will do my best to help.
Ween
Posted: November 12, 2005 at 4:17 PM / IP Logged
hi,
i think he could power the keyless entry directly from the battery, hot/non-switched side of cutoff solenoid, and be ok.
mark
tmpintnl
Posted: November 12, 2005 at 11:33 PM / IP Logged
Mark - exactly.  The plan is to connect the remote keyless entry to the battery side of the cutoff switch.  Using one of the available channels on the controller, I hope to be able to lock the doors, and then switch power off to the rest of the car.  If the keyless entry is also an alarm, the alarm will remain powered and active.  The reason for doing all of this is that the particular type of car that I am fiddling with has significant issues with battery drain because of some of the electrical device designs used.  Many owners of these cars have the typical cutoff switch with the big red handle or whatever, and this seems to be a little crude.  I would like to have the remote capability so that I don't have to fumble around with that.  A press of the remote, and all is shut down.  The cutoff switch that I plan to use shuts off power when the unit is grounded.  The purpose for the latching relay is to maintain a steady ground when pulsed by the keyless entry unit.  The cutoff switch restores power when the ground is removed.  Thanks for any guidance on latching relays.
Toby Peterson
