05 Equinox
Lmsc
Member - Posts: 13
Posted: November 11, 2005 at 7:51 PM / IP Logged
 I installed a remote starter in this truck last weekend and the Passlock & wrench lights come on when started by remote. I have the keysense wire (-) hooked up and I have the passlock bypassed. The lights only come on when remotely started, works great if you cancel the remote and then start it with the key.
lmsc
chriswallace187
Gold - Posts: 1,661
Posted: November 11, 2005 at 7:59 PM / IP Logged
Make sure you are powering both accessory wires as accessories and not ignitions. I did a Monte Carlo once with one of those two powered as ignition, and the passlock kind of went bonkers.
C Renner's Auto Electronix
Platinum - Posts: 12,488
Posted: November 11, 2005 at 9:05 PM / IP Logged
What bypass did you use ? Some of the modules that use a set resistor value are not as good as some of the self learning modules.
extreme1
Silver - Posts: 1,070
Posted: November 11, 2005 at 10:56 PM / IP Logged
I like using the PLXR with that vehicle as it has the keysense output on it.
make sure you've diode isolated your keysense from your bypass (ground when running)
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Lmsc
Member - Posts: 13
Posted: November 12, 2005 at 10:29 AM / IP Logged
Thanks guys for the info. I bought a new bypass and it works fine.
lmsc
