2002 honda civic install
cjohnston
Member - Posts: 17
Posted: November 17, 2005 at 6:04 PM / IP Logged
What, if anything, do I need extra to install an alarm/remote start on my '02 Civic. It is an EX model with factory alarm and all electric options. I think it has the anti-theft in the key but I'm not sure. The alarm that I'm installing is a Clifford RSX 3.5. If it has the anti-theft in the key, how do I interface/ bypass it? I'm new at this alarm stuff so any help is greatly appreciated.
I'll share my limited knowledge with anyone who can use it, and many thanks to those who share their knowledge with me.
cjohnston
Member - Posts: 17
Posted: November 17, 2005 at 6:20 PM / IP Logged
I found out for sure that it does have a transponder immobilizer system, now I need to know how to bypass it. If anyone can help,I would appreciate it.
05gt
Silver - Posts: 628
Posted: November 17, 2005 at 6:22 PM / IP Logged
you can either use the 556H to bypass the honda immobolizer, or you can use the 556U to bypass it aswell
With the 556U you will need an extra key to put inside of it
on the 556U the red wire goes to constant, the black wire goes to ground, and the blue wire goes to the ground out when running(-), or the status wire (-), from the alarm brain
infinkc
Copper - Posts: 438
you need a bypass module to bypass the anti theft key for the remote start, they make ones that you use your spare key, and ones that are programmable so you dont lose a key. if you dont have diodes you will need those for the door triggers
There are 10 types of people in the world, ones that understand binary and ones that dont.
cjohnston
Member - Posts: 17
Posted: November 17, 2005 at 6:26 PM / IP Logged
Okay, where do Iget the bypass module?
mo12v
Posted: November 17, 2005 at 7:28 PM / IP Logged
There are a number of places either On-Line or your Local 12volt Shop that you can get a ByPass
You can get them where it requires you to give up a Key or one that doesn't.  The later being a little more expensive, but a better way ...
OMEGA makes a few:
Honda/Acura Doorlock Alarm Interface (DB-HODL)
    2002 honda civic install -- posted image.
2002 honda civic install -- posted image.2002 honda civic install -- posted image.Honda/Acura Transponder Data Interface: TYPE-C (7 Wire) (IB-H3)
2002 honda civic install -- posted image.2002 honda civic install -- posted image.Universal Transponder Bypass w/ (PASS-4)
2002 honda civic install -- posted image.2002 honda civic install -- posted image.Platform#02: Upgradeable Multi Vehicle Can Bus Interface (IM-2)
2002 honda civic install -- posted image.2002 honda civic install -- posted image.Platform#05: Upgradeable Transponder Data Override (IM-5)
MO
