Parking, turn lights, etc problem.
ezaz
Posted: November 20, 2005 at 11:48 AM / IP Logged
Due to wrong connection during installation of a remote starter (designtech) with immobilizer bypass (---); parking lights, turn signals, fog lights and windshield washer pump of my Mitsubishi Galant 2003 are not working. I believe the problem occurred during connection of trunk release or keysense.  The remote start is working well.
I checked all the fuses, even uninstalled the remote starter, unfortunately nothing worked. At this point I do not care about trunk release. Please, advice to solve the problem
ezaz
Posted: November 20, 2005 at 12:05 PM / IP Logged
which one? I checked all the fuses under the hood and on  the side of the steering column. all showing continuity.
thanks.
dualsport
Silver - Posts: 983
Posted: November 20, 2005 at 10:40 PM / IP Logged
Did you measure voltage on both sides of the fuse to see that you get 12V? Particularly the fuse(s) that power the circuits that you're having problems with. If they're not all on the same fuse, did you disconnect any harness during the installation and maybe didn't latch them back in all the way?
ezaz
Posted: November 24, 2005 at 1:45 PM / IP Logged
I don't have voltage on fuse number 15 which is inside the inner fuse box and fuses #16, 17, 18, 19, 20, 21 which are under the hood.
thanks
kgerry
Platinum - Posts: 3,455
Posted: November 24, 2005 at 3:31 PM / IP Logged
i guess the thing to do would be to open the vehicles owners manual, ascertain WHICH fuse protects WHICH circuit and then check those specific fuses
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
dualsport
Silver - Posts: 983
Posted: November 24, 2005 at 5:22 PM / IP Logged
You're not measuring it while the ignition is off, are you? Don't know what those numbers correspond with, but it's highly unlikely that many fuses would be out from one incident. If your fuse panel shows what each fuse is for, just check the fuse for the turn signals, washer, etc, with the car running.
chris354
Silver - Posts: 253
Posted: November 24, 2005 at 9:47 PM / IP Logged
make sure you check the fusable links under the hood. I would also look for disconected harness if not those i would it is the ecu .
ezaz
Posted: November 29, 2005 at 10:07 PM / IP Logged
thank you guys for responding. I solved the problem --- it was a disconnected, positive 12 volt wire (brown) on ETAC.
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
