2004 GMC Denali SUV, Compustar 2WSS-AS
lukenco
Posted: November 22, 2005 at 5:14 AM / IP Logged
Hellow everyone,
Can someone help me find 2nd ignition wire on this car. I'm trying to install Compustar 2WSS-AS. I tried connecting 2nd ignition to 10gauge white from ignition harness, but car didn¡¯t stay on. I unhooked the 10 gauge white and car stays on, but now I got engine check light on. Wire diagram indicates white from ignition harness, but can¡¯t find any other white wire. One 16 gauge white I found was for emergency blinker. Can someone tell me how to find the 2nd ignition wire and how to reset the check engine light.
Thank you,
From Luke
Mike M2
Platinum - Posts: 2,652
Posted: November 22, 2005 at 6:57 AM / IP Logged
It is the 10g white, you were correct. The two ignitions are pink and white. If it's not starting there's another reason....
sparkie
Platinum - Posts: 2,061
Posted: November 22, 2005 at 9:20 AM / IP Logged
The first and second ignition wire as well as the starter and accessory wire come off the ignition switch and end at a plug on the backside of the driver's side fuse box.
sparky
Platinum - Posts: 12,488
Posted: November 22, 2005 at 10:29 AM / IP Logged
Make sure you use the 2nd IGN wire off the CN2 harness to engage the relay so the relay ( connect to PURPLE WIRE off IGN relay ) will stay on when cranking.
lukenco
Posted: November 22, 2005 at 12:14 PM / IP Logged
Hi,
does that mean starter wire is not 10 gauge yellow that goes into box by the break paddle?
Here are the wire connections for cn1 & cn2
12V to 10gauage Red  & RED / White at IG that goes into box by the break paddle.
Starter to 10gauage Yellow at IG that goes into box by the break paddle.
Accessory to 10gauage Orange at IG that goes to fues box by driver side door.
Ignition to 10gauage Pink at IG that goes to fues box by driver side door.
Ignition2 to 10gauage White at IG that goes to fues box by driver side door and connected status out from RS to IG2 relay (purple wire)
Are these connections right?
at this setup car don't start, starter motor runs but don't start. If I undo the 10gauge White, then car starts but check engine light comes on.
From Luke
lukenco
Posted: November 22, 2005 at 12:47 PM / IP Logged
correction
12v and starter ends at box above BMC.
From Luke
Mike M2
Posted: November 22, 2005 at 3:38 PM / IP Logged
I don't know the Comp product, but you are right on the vehicle wire colors. Red and RED / white 12v, pink and white ign, yellow start, orange accessory. I personally always use a relay and energize the second accessory, which is brown, but it's not needed.
sparkie
Posted: November 22, 2005 at 7:21 PM / IP Logged
Yeah you are right. I was having a brain fart. The yellow starter wire doesn't go to the back of the fuse box, but it goes into the large connector plug at the base of the steering colum.
sparky
lukenco
Posted: November 23, 2005 at 1:42 AM / IP Logged
Thanks guys, I found the problem. It was status output from RS that connects to 2nd IG relay. I'm getting constant 12V from that pin. So, I connected accessory out to 2nd IG and RS works. I will need to return the RS for replacement. Thanks for all your inputs.
From Luke
