2001 camry alarm/ remote start
start25
Copper - Posts: 114
Posted: November 22, 2005 at 5:16 PM / IP Logged
What diodes would I need to install the alarm/remote starter.  If I have 2 ignition wires and 1 ignition wire from starter unit how do I connect them both to the alarm so that the are not connected to each other?
05gt
Silver - Posts: 628
Posted: November 22, 2005 at 5:23 PM / IP Logged
use a relay
hook uo the ignition wire from the alarm/remote starter to the ignition wire in the vehicle
pin 85 goes to the ignition wire from the remote start/alarm brain
pin 86 goes to the alarm brains ground out when running wire/or (-) status wire
pin 30 goes to the second ignition wire in the car
pin 87 goes 12 volts (constant)
start25
Copper - Posts: 114
Posted: November 22, 2005 at 9:29 PM / IP Logged
How do you determine what door lock system you have on your car?
start25
Copper - Posts: 114
Posted: November 22, 2005 at 10:02 PM / IP Logged
Hello, I'm planning to install CRIMESTOPER alarm/ remote start on 2000 Camry with keyless intry option.
Please give me advise from your experience, this is my first camry...
How to install door lock option, what kinda door lock system does it have what do you do with the child safty wire?
Tech wire...
Factory alarm wire...
OEM Alarm disarm...
Mike M2
Platinum - Posts: 2,652
Posted: November 23, 2005 at 6:24 AM / IP Logged
Use blue for unlock and blue for lock, in the drivers kick. They meter from the key cylinder in the door. You don't need relays, direct hookup from the alarm brain. If you have a factory alarm this will arm and disarm it also. For tach use the black wire on the coil....
Mike M2
Tech Manager
CS Dealer Services
Mike M2
Posted: November 23, 2005 at 6:28 AM / IP Logged
Oopps! Brain fart. That's blue/white for lock....
Mike M2
Tech Manager
CS Dealer Services
Platinum - Posts: 12,488
Posted: November 23, 2005 at 8:16 AM / IP Logged
start25, do a search in the forums prior to beginning this installation as there is an abundance of information on the forums for the Toyota and it will benefit you alot if you just type in " Toyota Camry " in the search button above. You will find most if not all the information that you will need in order to get the RS installed.
start25
Copper - Posts: 114
Posted: December 06, 2005 at 4:17 PM / IP Logged
Hi,
I'm planning to intall alarm/starter (crimestoper) on 2001 Camry, Can you tell me what Alarm Input wire on the car is? What wire do you hook up to it?  Also it has child safety wire, what do I do with that, do I have to hook up door lock wires some special way?
Please help!!!!
Mike M2
Posted: December 06, 2005 at 4:48 PM / IP Logged
You use blue for unlock and blue/red for lock, either in the passengers kickpanel or the orange plug at the bottom of the fuse box. There is no child safety wire if you use these wire, test them by turning the key in the p;assenger door...
Mike M2
Tech Manager
CS Dealer Services
start25
Copper - Posts: 114
Posted: December 07, 2005 at 2:12 PM / IP Logged
Thanks alot, inntalled succesefully!!!
