Heated seats ? with remote start
brianh
Silver - Posts: 518
Posted: December 14, 2002 at 5:59 PM / IP Logged
Has anyone installed a relay to activate their heated seats when the car is remotely started?  I thought of it the other day and it seemed easy enough to do.    Brian
securinu
Silver - Posts: 772
Posted: December 14, 2002 at 6:08 PM / IP Logged
i did in my durango it is a nice add-on it was simple in mine , just like doing doorlocks in any chrysler ground thru a resistor for high or low i went with high resistor to warm up faster then i can put on low when in the truck
Moderator - Posts: 12,488
Posted: December 14, 2002 at 6:23 PM / IP Logged
Did you do trial and error for the right resistance or was it in the Haynes manual for the truck for the proper resistors ?
securinu
Silver - Posts: 772
Posted: December 14, 2002 at 7:00 PM / IP Logged
i have a service manual  so i got the exact value.
brianh
Silver - Posts: 518
Posted: December 14, 2002 at 8:59 PM / IP Logged
I am thinking about doing them in brothers 1999 Ford Explorer.  Where would be the best place to find the wire at.(I quess you could right at the harness under the seat?)Also should you have to use a resistior with the Explorer setup.  If so I have the Hayes manual.  Thanks for the help.  Brian
iskidoo
Silver - Posts: 1,046
Posted: December 15, 2002 at 8:36 AM / IP Logged
Hey brian when you get that all hooked up can you send me an email. I think i might try that on a 99 Exploror if its easy enough to do.  Thanks...if you give a brief description of what you did I would appreciate it.
Steve G
themagicone
Silver - Posts: 325
Posted: December 15, 2002 at 7:32 PM / IP Logged
Why botther with doing that? Just make sure you hook up all ACC and ING wires and just leave it one when you get out of the car. When you remote start it will be active and the seat will warm up.
iskidoo
Posted: December 15, 2002 at 8:21 PM / IP Logged
Well if your like me...I'm lucky if I remember to turn my heat controls up before I get out of the vehicle, let alone turning stuff like that on. Once I'm warm I don't think about cranking the heat before I get out....LOL
Steve G
TTopStang
Member - Posts: 19
Posted: December 16, 2002 at 5:28 AM / IP Logged
SECURINU, I have a 99 Durango and decided to get an Autopage rs750lcd. I wanted the Viper 790xv but cost and availability turned me to the autopage. To get to the point... I want to get some preliminary ideas as to what I am going to do before the day comes so that way I don’t start installing it and then have to stop think if I made the best decision. Since I noticed you had a Durango and a Marksman I hope you don’t mind me asking you some direct questions. I was going to put the brain behind the driver’s kick panel, the temperature sensor in the center console, the valet switch either in the center console or somewhere hidden under the passenger side dash. Sensors, I’m still deciding. In what locations did you mount the brain and sensors? Thanks.
securinu
Silver - Posts: 772
Posted: December 16, 2002 at 5:07 PM / IP Logged
email me direct and i will include a diagram and resistor values .. also tell me what model d you have also have you been to dodgetalk.com . i moderate a couple of forums over there and they have a lot of info
i go by RTDurango over there
securinu@attbi.com
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
