Hyundai Accent keyless bug
xxmattfxx
Copper - Posts: 57
Posted: November 25, 2005 at 5:33 PM / IP Logged
I put a dei keyless entry into a 2003 Hyundai accent complete with driver door actuator...the problem is that occasionally when in drive the locks will keep locking and unlocking at consistent intervals.  I don't know if the unit itself isn't progamed correctly or if there is a conflict with the system...any insight?
desh187
Copper - Posts: 310
Posted: November 25, 2005 at 8:10 PM / IP Logged
I am sure it is the alarm module which you should change as i have experienced similar problem in another vehicle.
xxmattfxx
Copper - Posts: 57
Posted: November 25, 2005 at 9:48 PM / IP Logged
is it a setting or an actuall defect in the unit?
yg17
Member - Posts: 34
Posted: November 28, 2005 at 9:45 AM / IP Logged
possibly a bad actuator, I had the same problem in my 04 Hyundai Tiburon. Dealer replaced the actuator and its fine again
desh187
Copper - Posts: 310
Posted: November 28, 2005 at 5:47 PM / IP Logged
It would be an actual defect in the unit but i would also turn off start lock feature in the alarm which would prevent the doors locking and unlocking when you start of shut off your car
