Alarm/Remote start in 2001 corolla?
lxmantisxl
Member - Posts: 6
Posted: November 26, 2005 at 11:22 AM / IP Logged
Iwant to put a alarm/remote starter in my car. I've seen this note pop up on a few sites:
NOTE: DO NOT ATTEMP TO START THE VEHICLE WITH THE STARTER WIRE CUT IT MAY POP THE AIR BAG. DO NOT INSTALL A STARTER IMOBILIZER
    Does this mean I can't use the starter didable feature on the alarm??
Mike M2
Platinum - Posts: 2,652
Posted: November 26, 2005 at 11:42 AM / IP Logged
Never heard of such a thing. Done a million Corollas, with a million kills.....
Mike M2
Tech Manager
CS Dealer Services
JWorm
Platinum - Posts: 2,208
Posted: November 26, 2005 at 11:53 AM / IP Logged
That would be a great feature. Thief gets in car with alarm on, jams screwdriver into ignition and turns it....BAM....airbag to the face. You come walking out to the car and find the guy knocked out in your drivers seat. Proceed to give the scumbag another beating and then call the cops.
JWorm
Posted: November 26, 2005 at 11:55 AM / IP Logged
What company's tech sheet has that warning? DEI doesn't mention anything special about it
lxmantisxl
Member - Posts: 6
Posted: November 26, 2005 at 4:49 PM / IP Logged
It's actualy on this forum under wiring guides for the 01 corolla he says
Moderator
Posts: 9,217 Posted: March 29, 2002 at 12:03 AM - IP Logged
2 nd ignition wire will need a relay ( unless the unit that your installing has built in relays for this circuit ).
the door lock system is tricky. go here for more info:http://www.bulldogsecurity.com/wires/images/toysafelock.htm
There Are Mulitple RED / White Wires Near The Fuse Box. Some Will Work Individual Doors Only. Test With A Meter To Identify The Single Wire That Reacts To All Doors.
For Dome Light Supervision, Use One Of The Individual Doors.
Alternate tach wires : YELLOW /GREEN OR RED / BLUE AT IGNITION COILS
cntrylvr79
Silver - Posts: 582
Posted: November 26, 2005 at 7:39 PM / IP Logged
That's kinda funny actually.  Someone probably cut the wrong wire for the starter kill
Cause I'm So white and nerdy...
First Class Certi-fried installer
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
