Tilt Steering Memory, 97 Acura 3.5RL
six2six
Copper - Posts: 60
Posted: November 30, 2005 at 9:15 PM / IP Logged
I have a 97 Acura 3.5RL and the vehicle has power tilt steering, so when the key is inserted into the ignition the steering wheel moves to a preset position and when the key is removed from the ignition the wheel goes back up to the rest position. My problem is that when I remote start the vehicle with my compustar is that the vehicle loses the steering wheel memory and I have to manually lower the steering wheel.  Any help will be grealty appreciated.
jdeezay
Member - Posts: 28
Posted: December 01, 2005 at 6:25 PM / IP Logged
find the key sense wire and hook up the status output to it the output acts like the in the ign. you may need to wire up a relay to it if it does not work of the status output it self
jdeezay
Member - Posts: 28
Posted: December 01, 2005 at 6:37 PM / IP Logged
im a moron i can not type hook up the status output to the key sense at the key cylinder it acts like the key is in when you remote start or if it has memory seat settings diode isolate the unlock wire and pulse the memory number setting i would try the key sense first
Geeque
Silver - Posts: 310
Posted: December 02, 2005 at 4:12 PM / IP Logged
Or just interupt the tilt steering wire upon starting, this should work fine.
Gary Kline
MECP Master Technician
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
