tuning amp, hifonics brutus
-94-accordh22
Copper - Posts: 53
Posted: November 30, 2005 at 9:56 PM / IP Logged
hi all.
just installed my stereo and i got:
hifonics brutus 1500W mono D
and 2 15" audiobahn special edition subs.
i dont know how to tune the equil. on the amp for optimum performance? what should the dials be set at. (level, eq, 0-180 degrees, gain, etc.)
thanks
DYohn
Platinum - Posts: 10,741
Posted: November 30, 2005 at 10:10 PM / IP Logged
Are your subs in a sealed or ported enclosure?  Are you using a HP crossover on your mains?
Click the "search" button and look for "setting gain" and carefully follow those instructions.  Leave the phase control and bass EQ set to "0".  Set your LP filter somewhere between 80Hz and 120Hz.
-94-accordh22
Copper - Posts: 53
Posted: November 30, 2005 at 10:19 PM / IP Logged
its a ported box. no crossovers.
so phase stays at 0
last time i checked when i put EQ to 0 no sound comes from the subs. but i may be thinking of a different knob
thanks
geepherder
Platinum - Posts: 3,668
Posted: December 01, 2005 at 4:48 PM / IP Logged
0 in this case is the phase of the signal, not the strength of the sound level (as in the case of your eq).  If you seem to have bass problems, you can try 180 to see if it's improved any.
