commando 4040 ground out while rs
minhbach
Copper - Posts: 93
Posted: December 02, 2005 at 12:41 AM / IP Logged
Would any body help me out with this commando 4040 which i purchase from asianwolf. It doesn't have a ground out during remote start wires. How can I make that to happen in order to tap the 555H or 556u bypass transponder for honda accord 2001. Here is the wiring diagram for commando 4040.
1O PIN HARNESS
white         parking lights
red            12V+ power
brown        Alarm siren outputs
orange     (-) Armed output
gray          Spark Plug Sense
Green       (-)Door Trigger
Blue          (+) Hood trigger
Violet         (+) Door trigger
Yellow       Brake Light Switch
6 PIN HEAVY GAUGE HARNESS
Violet      Starter
Orange  Accessory
Yellow  Ignition 1
Brown  Ignition 2
red     12V+
red    12V+
minhbach
Copper - Posts: 93
Posted: December 03, 2005 at 1:19 AM / IP Logged
10 harness missing a black wire for ground. Anybody help out...............
Mike M2
Platinum - Posts: 2,652
Posted: December 03, 2005 at 8:06 AM / IP Logged
If it doesn't have one you can always tap off  the yellow ignition to a relay and flip it to a negative.
Mike M2
Tech Manager
CS Dealer Services
minhbach
Copper - Posts: 93
Posted: December 03, 2005 at 4:15 PM / IP Logged
Is this the relay diagram i should use to convert positive to negative at yellow wire at ignition 1
commando 4040 ground out while rs -- posted image.
So 86 go to ignition 1 wire (yellow) and 30 and 85 go to ground, 87 gonna be my ground output during remote start which needed to be hooked up to the by pass correct.
minhbach
Copper - Posts: 93
Posted: December 09, 2005 at 1:42 AM / IP Logged
Hello........
redpeppers
Silver - Posts: 483
Posted: December 09, 2005 at 3:46 AM / IP Logged
yes that is the right relay
Where theres is a wire there's a way.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
