volvo xc90 remotestart
midospike
Member - Posts: 9
Posted: December 02, 2005 at 11:08 PM / IP Logged
Hello, I am buying a 2006 volvo xc90. Looking for a wire diagram to istall it. Also.. is there a cheaper place to get the ipod connector then the dealer. any help would be great thanks
rayrobson
Member - Posts: 16
Posted: December 11, 2005 at 3:27 AM / IP Logged
Don't do it! xc90 has multiplex everywhere, the only model of Volvo that you won't void the warranty on is the 40 series. I have attempted r-start on these vehicles....run away.
H2s H3s Escalades Denalis all day everyday....if you need help with these vehicles PM me...If I don't know I will find out!
pattyweb
Posted: January 09, 2006 at 7:54 PM / IP Logged
There is no IPOD connector for this vehicle. There is no AUX-IN either.
You should be able to install remote start on this. There is a CAN-SL module to give easy access to most alarm functions via two connections to the OBD connector. The only other wires you'd need to hook into are +12v,Starter, and Ignition. Goto http://www.autoland.ca/byPassModule/selectShow_all.asp?comefrom=2
Then just the hassle of installing a transponder bypass and getting the antenna for it setup correctly.
I also just got an 06 and will be attempting this soon.
Friday, December 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
