Do I need a bigger alternator?
ryan2100
Member - Posts: 12
Posted: December 04, 2005 at 5:32 PM / IP Logged
In my 350z i will be running about 1000watts of total power to my sub and speakers.  There will be two amps, a diamond audio D7152 running 600x1 @4ohm, and a diamond d7104 running 100x4 @4ohm.  Diamond provides a rough estimate on the amperage of each speaker which says it is 100amps for the D7152 running at 600x1 and 66amps running at the 100x4.  I believe that this makes the total amperage on my car 166.  Will i be able to run these amps on my car alternator/battery or do I need an upgrade of some sort.
Ryan
dwarren
Posted: December 04, 2005 at 5:47 PM / IP Logged
Find out the output of your stock alternator. Then factor in other accessories you might use, like head lights, heater, etc. Your chances are unlikely with that sort of draw.
geepherder
Platinum - Posts: 3,668
Posted: December 04, 2005 at 5:48 PM / IP Logged
Wow- if those numbers are accurate, those are some power-hungry amps.  Definitely upgrade your alt.  Look for one rated at 200+ amps.  The big 3 is a must as well- do a search if you're unsure about what this entails.
Alpine Guy
Platinum - Posts: 2,478
Posted: December 04, 2005 at 10:57 PM / IP Logged
Since you spent that much money into getting everything of such high quality, you may as whell back them up with a more than powerful electrical system such as a replacement battery for that factory nissan battery, look into the kenetik batterys everyone is talking about, and definately send them an e-mail at  www.mechman.com  for a high quality unit.
haemphyst
Platinum - Posts: 5,059
Posted: December 05, 2005 at 10:06 AM / IP Logged
YES, you will need an upgrade in the alternator department. There is no stock alternator in the world that will handle an ADDITIONAL (potential) 166A load, or even an additional (potential) 100A load... Save yourself the headaches, and do the alternator and Big 3...
