security light, 2002 pontiac grand am
schristopher
Posted: December 05, 2005 at 2:52 PM / IP Logged
I have a 2002 pontiac grand am. the problem is that sometimes the factory alarm system malfunctions leaving the car undrivable. then you have to leave the ignition key in the on position for ten to fifteen minutes and then it will start.
how do you disable this system so that the car will start normally?
sparkie
Platinum - Posts: 2,061
Posted: December 05, 2005 at 5:31 PM / IP Logged
you can't disable the system. The Passlock II system is a factory theft immobilizer. Take it to a GM dealer and have them diagnosis the problem. You can't bypass this system you can only duplicate it as when you are installing a remote starter.
sparky
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
