arrow 3 and sensor probs
jinjur
Posted: December 06, 2005 at 5:15 AM / IP Logged
Hello,
Ok....some of my problems gone....a couple remain.
On my arrow 3, when i plug a proximity sensor 3 into the single zone input and a duplex piezo sensor into the dual zone input, the light on the piezo sensor stays on.
Does anyone know why this is?
When i remove the proximity sensor the light goes out on the piezo sensor
HELP
jinjur @ belfast @ n.ireland
scirocco16v
Copper - Posts: 112
Posted: December 06, 2005 at 11:11 PM / IP Logged
First check to see if the prox sensor is putting out constant ground with a meter it could be defective.  If it is not, put a diode in line with the shock sensor orange wire,  with the band facing the sensor.  By the way, I have done similar setups with that alarm and never had to diode, might be a bad sensor.
jinjur
Posted: December 07, 2005 at 4:10 AM / IP Logged
Hi Scirocco,
Thanks for your reply......i havent checked anything with a meter yet but i just assumed it would all...well...y'know...work.
Will check that tonight.........i hope its not a busted sensor.....wont be happy
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
