2000 Ext. Cab S-10, box for one 12 pyle
recycle_me
Posted: December 08, 2005 at 10:56 PM / IP Logged
i have a 2000 s-10 ext cab and i would like to build a box for one 12 inch pyle (PL1290BL). just a square sealed enclosure.
!?!For You Are Crunchy and Taste Good With Ketchup!?!
dwarren
Posted: December 08, 2005 at 10:58 PM / IP Logged
Did you have a question? Or is this a statement?
recycle_me
Posted: December 08, 2005 at 11:45 PM / IP Logged
question! i need the box diam. so i can build it.
menace2sobriety
Silver - Posts: 394
Posted: December 09, 2005 at 12:11 AM / IP Logged
whats wrong with the cardboard box it came with? Woofer Enclosures  <---if you can see this click on that.
dwarren
Ok, we need the air space requirements for the sub, then the measurements from the vehicle (the area where the box will go).
Mr. sobriety has the link there for you.
recycle_me
Posted: December 09, 2005 at 12:27 AM / IP Logged
power peak    1200
ohm     4
fs(hz)  23.2
qms     4.92
qes     .84
qts     .72
spl     85
vas     4.908
thast all i could find on the sub. i tried to use winisd but no luck. and as far as the space i dont care how big the box has to be. just make it square.
dwarren
Posted: December 09, 2005 at 12:44 AM / IP Logged
Ok, make a box that is 15.5"(width)  x 15.5" (height) x 15.5" (length) with half inch stock. This will net you an internal volume of 1.76 cuft and a damn square box.
I guesstimated on the volume requirements.
OR
Buy a prefab box and be done with it.
recycle_me
Posted: December 09, 2005 at 12:45 AM / IP Logged
thanks
stevdart
Platinum - Posts: 5,816
Posted: December 09, 2005 at 7:56 PM / IP Logged
Ummmm....
I think someone just made up those specs you found for that sub.  EBP of 27??  I second the notion of buying a pre-fab box that fits your truck.  To hell with how big or little it is.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
