94 Altima Remote Starter Issue
mb07
Member - Posts: 44
Posted: December 12, 2005 at 10:56 PM / IP Logged
Everything is hooked up and working but Ignition and Second Ignition both do not turn on the heater and fan inside the car.  Any tips on this?
silvercivicsir
Copper - Posts: 416
Posted: December 12, 2005 at 11:17 PM / IP Logged
did you hook up the accessory ?
mb07
Member - Posts: 44
Posted: December 12, 2005 at 11:22 PM / IP Logged
yup.  i threw a compustar in there which wants accessory, ignition and second ignition i used that realy it comes with just like every other car but this one particular car is just getting on my nerves.  maybe i should re check the accessory?  but the car is remote starting no problem its just the heat isnt coming out till the key is in there and turned etc.
dmielken
Copper - Posts: 63
Posted: December 13, 2005 at 11:29 AM / IP Logged
What color wire did you power for accessory? Normally when the heater doesn't come on it's a case of the accessory wire linked to it not being powered. Should be Red coming from keyside to a connector, after the connector it should be BLACK/ Red.
thepencil
Gold - Posts: 1,526
Posted: December 13, 2005 at 12:28 PM / IP Logged
Accessory is RED to BLACK/ pink.
You will need to set the jumper to second STARTER not ignition.
Follow the diagram below to connect the accessory wire.
1077.pdf
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|wht/red to white    |+ |ignition harness            |
|          STARTER|blk/yel to blk/wht |+ |ignition harness            |
|   SECOND STARTER|blk/grn to blk/yel |+ |ignition harness            |
|        IGNITION|blk/wht to blk/red |+ |ignition harness            |
|        ACCESSORY|red to BLACK/ pink *1|+ |ignition harness            |
|       POWER LOCK|gray/blue           |- |at door lock timer *2       |
|     POWER UNLOCK|gray/red            |- |at door lock timer *2       |
| PARKING LIGHTS +|RED / blue            |   |steering column             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|RED / blu,RED / yel *3 |+ |steering column             |
|     DOOR TRIGGER|RED / white           |- |drivers kick panel          |
| TRUNK/HATCH PIN|red                 |- |at right hinge, *4          |
|        HOOD PIN|yellow/black        |- |at pin or *4               |
|TRNK/HTCH RELEASE|                    |   |                            |
| FCTRY ALARM ARM|lt. GREEN/ red       |- |harness from dr. door       |
|FCTRY ALRM DISARM|GREEN/ YELLOW        |- |harness from dr. door       |
|       TACHOMETER|green               |   |coil or ECU center dash     |
|       BRAKE WIRE|RED / green           |+ |brake pedal switch/dkp      |
|     HORN TRIGGER|GREEN / WHITE        |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|blu/blk - blu/red   |A |in the L.F. door            |
| RF WINDOW UP/DN|blu/blk - blu/red   |A |in the R.F. door            |
| LR WINDOW UP/DN|blu/blk - blu/red   |A |in the L.R. door            |
| RR WINDOW UP/DN|blu/blk - blu/red   |A |in the R.R. door            |
Notes:
*1 When doing remote start, this wire must be isolated from the keyswitch with the accessory relay. See direct fax document #1077.    *2 Timer is a blk or grn box located right of fusebox behind a silver module or up high in the drivers kick behind a silver module, depending on model. Two plugs, white and black. The wires needed to control locks are in the black plug. *3 these colors are for low beam. to catch high beam use RED / black(+) and RED / green(+). *4 also found at the theft warning system in the drivers kick behind the ABS control unit if equipped with factory security.
Be careful whose advice you buy, but be patient with those who supply it.94 Altima Remote Starter Issue -- posted image.
mb07
Member - Posts: 44
Posted: December 13, 2005 at 11:06 PM / IP Logged
sorry you lost me there..set the jumper to the second starter wire?
chris354
Silver - Posts: 253
Posted: December 14, 2005 at 12:15 AM / IP Logged
That car has only 1 acc and 1 ign. it has a second starter but that should not effect the heater. Turn the ign. to acc psition then check the remote start wire to see if has power on it . If you dont then redo the connection for the acc wire. Also while testing the acc wire try remote starting and see if the unit is putting out an acc.
thepencil
Gold - Posts: 1,526
Posted: December 14, 2005 at 12:49 PM / IP Logged
"sorry you lost me there..set the jumper to the second starter wire?"
Connector #8
Open up the module by sliding the cover back. Where you cut the green jumper wire for (automatic transmission installation) you will see three sets of pins. They will be mark. STARTER, ACC, IGN.
mb07
Member - Posts: 44
Posted: December 14, 2005 at 11:21 PM / IP Logged
but leave my wiring as it is?
thepencil
Gold - Posts: 1,526
Posted: December 15, 2005 at 9:39 AM / IP Logged
Yes.
