Toyota 4Runner 02
Ohmz
Copper - Posts: 193
Posted: May 09, 2002 at 8:27 PM / IP Logged
Well this is my first time registering.  I have two simple question. I wanted to know if there is an ignition anti-theft system on this vehicle. I want to install an alarm/remote starter. I've installed a couple of remote starters in cars where I'd have to hide the key under the dash with a special module DEI makes. I would think this is the same piece I need? I also need to know if there are any other special installation guide lines I need to know about this vehicle cause they were pretty easy to locating the wires?
My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
Moderator - Posts: 12,488
Posted: May 09, 2002 at 9:15 PM / IP Logged
The 2002 4Runner does have a immobilizer that you have to bypass.
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GREEN/ BLACK
IGNITION SWITCH HARNESS *
Ignition  #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT IGNITER ON PASS. WHEELWELL **
Parking Lights:
RED / GREEN (-)
AT ALARM MODULE
Headlights:
RED (-)
AT HEADLIGHT SWITCH ***
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
BLACK / YELLOW (+)
AT ALARM MODULE
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 2000 Vehicles May Be Equipped With a Transponder Type ** BLACK Tach Wire Also Found In Data Link Connector On Driver Side Of Engine (4 Cyld.) Or At Engine Control Module Located Behind Pass. Dash (6 Cyld.) Or Can Also Be Found In 26 Pin Connector In Pass. Kick Panel On Both.
Toyota
4-Runner
1999-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED & WHITE
Starter  Kill:
GREEN/ BLACK
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
GREEN/ BLACK (-)
AT DOME LIGHT
OEM Horn:
GREEN/ RED (-)
AT ALARM MODULE
Power  Lock:
RED / WHITE (-)
WHITE CONN. ABOVE BLUE IN DR. KICK***
Power  Unlock:
RED (-)
Trunk  Release:
Alarm  Input Wire:
GREEN/ BLACK (-)
AT DOME LIGHT
Notes:
** Fuse Block Located In Driver Dash. *** Child Safety Locks: RED / BLUE (-) In Same Conn. As Door Lock Wires Above. Child Safety Locks. Lock Wires Are Also Found At Alarm Module. Lock BROWN / White (-) Unlock GREEN/ YELLOW (-)
Drahcir
Member - Posts: 11
Posted: November 21, 2002 at 7:08 AM / IP Logged
Thanks a lot...
Chris Luongo
Platinum - Posts: 3,746
Posted: November 21, 2002 at 5:18 PM / IP Logged
I can't remember if every 4Runner has the immobilizer---but most of them do.  And yes, you would use the key-in-the box bypass.  If you don't want to give up a key, I think DEI's 555F Ford module can work on Toyotas---not absolutely sure though.
A while back, I posted some other information on the 4Runner, including how to roll the rear window down with one easy relay-- search and see if you can find it.
anonymous
Member - Posts: 24
Posted: November 21, 2002 at 6:17 PM / IP Logged
DEI says that it does have an immobiliser, and that you can use the Ford one 555F
Sunday, November 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
