01 Isuzu Rodeo, 1256M Ultrastart
iskidoo
Silver - Posts: 1,047
Posted: December 22, 2005 at 5:03 PM / IP Logged
Hey folks, Installing a 1256M Ultrastart into an 01 Isuzu Rodeo later and wanted a heads up on the parking brake wire. Do I need to get it at the brake or is there a easier place to grab it like the passenger kick? Thanks for any help you can offer.
Steve
Steve G
KarTuneMan
Platinum - Posts: 7,056
Posted: December 22, 2005 at 5:57 PM / IP Logged
Pink/black at the brake switch NEG(-)
iskidoo
Posted: December 22, 2005 at 6:41 PM / IP Logged
Thanks Gary, do you have any idea what the trick is with the clutch bypass. I only see a 2 wire connector on the front of the assembly that is smaller guage. But even when jumpered does not turn over. Only turns over when I held the clutch down. It seems as if maybe there is another switch not on the inside of the firewall??
Steve G
iskidoo
Posted: December 22, 2005 at 7:02 PM / IP Logged
Nevermind, I found another switch that was obstructed from my view.
Steve G
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
