02 explorer door lock
Alpine Guy
Platinum - Posts: 2,478
Posted: December 23, 2005 at 12:54 PM / IP Logged
I did a TW unit on a 2002 Ford Explorer and the only thing that isn't really a problem, but more of an inconvenience is the fact that after locking it with the factory remote, the aftermarket signal wont work.  I tryed finding the GREEN/ purple in the door boot, i found 3, 1 is a positive, so 2 could be the factory disarm, yet none of them do a dang thing.  What do i need to do the "wake up" the veh for it to accept the unlock signal after being locked with the factory remote?  And which is the actual real disarm wire?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 23, 2005 at 1:19 PM / IP Logged
Are ya looking low in the kick, almost in the running board area? You can also pulse ANY of the buttons on the pad on the door...this will also wake up the BCM.
chris354
Silver - Posts: 253
Posted: December 23, 2005 at 8:42 PM / IP Logged
mo12v
Posted: December 23, 2005 at 8:53 PM / IP Logged
Due To Accessory Power Loss At Generic Electronic Module, Power Door Locks Will Become Inoperable 2 Minutes After Last Door Is Locked And Closed.To Wake up the G.E.M Send A Negative Pulse To The YELLOW/BLACK Driver Door Pin Wire With the Unlock Pulse. Diode Isolate.Cathode(Band Side)Of Diode Faces away from vehicle wires.YELLOW/BLACK Found In Drivers Door Boot It Is One Of Three.
MO
Alpine Guy
Posted: December 23, 2005 at 11:03 PM / IP Logged
perfect, i appreciate the help!
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
