98 Ford Explorer Remote Start Problem
nnegrini
Posted: December 31, 2005 at 4:32 PM / IP Logged
I am putting a Avistart 4400 in a 98 Explorer.  I have everything hooked up and the remote start just cranks (it never fires).  It has the 555f installed, to I not have it learned correctly.  Any ideas??  I am assuming it is the 555f, could it have something to do with the Factory Alarm??
catalin capota
Copper - Posts: 74
Posted: December 31, 2005 at 4:35 PM / IP Logged
Lights turning on in the dash? Could be an ignition problem?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 31, 2005 at 5:28 PM / IP Logged
Check the location of the "pellet" on the key cylinder. ALSO...will it start with the key in the ignition? The 555f is just the ignition imobilizer bypass, has nothing to do with the factory security.
nnegrini
Posted: December 31, 2005 at 7:25 PM / IP Logged
It starts fine with the key in the ingition, I have to work on the 555f any suggestions on programing tricks??  Thanks in advance
