2nd ignition wire
jmacf14
Copper - Posts: 160
Posted: January 01, 2006 at 1:28 PM / IP Logged
 does the second ignition wire(selectable output on my ultrastart alarm) have to stay energized at start position like the 1st ignition wire. i found two wires that energized at run position but not in off or acc. one stays energized at start w/the starter wire, the other does not stay lit.  is this normal? does it sound correct?  tnx
jmacf14
mo12v
Posted: January 01, 2006 at 7:57 PM / IP Logged
Not knowing what Vehicle .........
Usually, but it can depend on vehicle
MO
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
