Viper 160XV Memory Seat
xxmattfxx
Copper - Posts: 57
Posted: January 03, 2006 at 10:02 AM / IP Logged
I am attempting to hook up the memory seat to be linked to channel 2 and 4.  But the problem is that I can not get the brain to distinguish between the two remotes, anything I program to one of them...it programs to both.  Does this viper unit support the ability to have two different setting depending on which remote you use?
gus1
Gold - Posts: 1,013
Posted: January 03, 2006 at 10:08 AM / IP Logged
Yes. The beauty of ESP2.... up to 4 different remotes with their own settings. Having a bitwriter helps.
Gus
xxmattfxx
Copper - Posts: 57
Posted: January 03, 2006 at 11:13 AM / IP Logged
That's the problem, it won't recognize the remotes as being different.  I have a bitwriter v2.0 but it says it's an unrecognized module when I plug it in.
gus1
Gold - Posts: 1,013
Posted: January 03, 2006 at 1:46 PM / IP Logged
Interesting...... may need to update the bitwriter. It it one of the new 160XV's with the programmable start delay?
You should be able to program using the valet switch and LED as well....
Gus
kgerry
Platinum - Posts: 3,455
Posted: January 03, 2006 at 1:56 PM / IP Logged
when you set up features choose a remote and learn it as remote 1 then program your other features as remote 2.... if you program to 0 it learns to ALL remotes.. but it is very easy to program remote specific features....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
xxmattfxx
Copper - Posts: 57
Posted: January 03, 2006 at 2:13 PM / IP Logged
but my bitwriter isn't working with this unit, and yes it is one of the new viper's...so that may be the reason
cntrylvr79
Silver - Posts: 582
Posted: January 03, 2006 at 8:38 PM / IP Logged
You need to update the bitwriter to be able to program the new viper I think the newest version is 2.2
Cause I'm So white and nerdy...
First Class Certi-fried installer
xtremca2003
Member - Posts: 37
Posted: January 03, 2006 at 10:07 PM / IP Logged
You can buy the update chips for the bitwritter for about 10bucks. Do a search on the net.
Chris
xxmattfxx
Copper - Posts: 57
Posted: January 04, 2006 at 9:54 AM / IP Logged
I can only find v2.0 on the net, and that's the version I already have that doesn't recognize the module
