Galaxy 5000RS not reading remote
etm0r0n
Posted: January 06, 2006 at 7:43 PM / IP Logged
i installed the alarm and everything seemed right so far .
i turned the key to the " on " position 4 times and the siren chirped and i pressed the overide switch and everything is great but nothing happens when i press button 1 on the remote .
so i tried to do it over and over and nothing happens .
did i install the antenna wrong or something ? i checked it several times and even stuck both blue and white connector into the antenna box .
help me please . this is for a 1995 nissan 240sx SE .
also i leave the battery in the remote , do i have to take out the battery to reset it or anything or do i have to reset the alarm itself too .
thank you in advance .
Powermyster
Silver - Posts: 962
Posted: January 06, 2006 at 7:57 PM / IP Logged
on,off,on,off,on,off,on siren will chirp when in the on position press and hold the valet switch for 5 seconds the siren will chirp and LED stay on then press button 1
button 1 on the lcd pager is the arm and disarm button
you should not need to replace the battery in the remote but i would do it just in case.
make sure the valet and ariel are plugged in right..
doe both the pagers not work
Why oh Why didn't i take the blue pill
Darren Power
etm0r0n
Posted: January 06, 2006 at 9:15 PM / IP Logged
i did all that but when i pressed the button 1 nothing happens at all .
i changed the battery on BOTH remotes but still nothing.
im 100% sure the valet switch is plugged in right but what is a " ariel " plug ?
so far i kept trying and kept pressed button one . i even tried to take out and put the battery back in while the led was lit , but nothing happens .
any other ideas ?
thank you
Powermyster
Silver - Posts: 962
Posted: January 07, 2006 at 10:45 AM / IP Logged
by ariel plug i mean the antenna plug. where did you get the system
Darren Power
etm0r0n
Posted: January 07, 2006 at 11:53 PM / IP Logged
i got it from ebay about 2 years ago ... i figured hey theres an alarm might as well just install it . but yeah still not reading .
one time i just pressed it and it worked but litterally less then a min later it didnt read the remote anymore so i know the antenna and everything works . even started the car with remote start .
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
