VSS wire for 1989 Mazda RX-7 Convertible
audioduck
Member - Posts: 25
Posted: January 09, 2006 at 7:06 AM / IP Logged
Need to find VSS wire for 89 RX-7 in order to hook up Autosound (Speed sensitive volume) for Blaupunkt Acapulco MP52 head unit.
airandsound
Copper - Posts: 69
Posted: January 09, 2006 at 3:57 PM / IP Logged
Don't think pre 90 models had a VSS
audioduck
Member - Posts: 25
Posted: January 09, 2006 at 4:20 PM / IP Logged
Hmm, I thought it did.  I've done some investigation on the wiring diagrams for the car and found a wire (G/R if that matters) that goes between the instrument cluster and the cruise control brain which I suspect might be VSS or similar.  It also has speed sensitve power steering which, it was my understanding, is VSS controlled.
I wonder if it would be safe to experiment with tapping the headunit VSS lead into the wire I found on the wiring diagram.  Anybody have any opinions on this?
(I'll probably to it anyhow - can't resist the temptation.)
sparkie
Platinum - Posts: 2,061
Posted: January 09, 2006 at 5:19 PM / IP Logged
Use a volt meter set on an A/C voltage scale and measure from a good ground to the wire while moving forward. If you get an A/C signal you should be good to go.
sparky
Wednesday, July 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
