Remote Starter Issues, 2006 Tahoe
progboy
Member - Posts: 7
Posted: January 09, 2006 at 7:58 AM / IP Logged
I have installed a Audiovox remoter starter/security system on my 2006 Tahoe. I've spent a few days installing it and now I have run into a road block. 2 issues...
1) I can't determine which wires to tie into to control the door lock and unlock.
2) The remote starter will start the truck, but then the factory security system engages and kills the truck instantly.
Now there are 3 wires in the remote starter that should handle this issue.
The first send a signal 1.5 seconds before start (I hooked this up to disengage the factory security system). Works perfect.
The second will send a signal after remote start shuts down to lock the doors.
The third sends a signal during start. This is the one that should override the factory security system, but I don't know where to tie it in.
Can someone help me?
mo12v
Posted: January 09, 2006 at 8:13 AM / IP Logged
Best thing to do is get a Qualified Installer
Otherwise............
If you would use the CORRECT ByPASS for this vehicle it would help .........
OMEGA makes a ByPASS that incorporates the PassLock &  Door Locks, not to mention Other Features that would make the Install a LOT easier
MO
progboy
Member - Posts: 7
Posted: January 09, 2006 at 8:20 AM / IP Logged
The Audiovox system I have should have the correct bypass. I just don't have any instruction on how to tie it into my truck. Audiovox install instructions are poor at best. So I had to do a lot of research to install what I do have. And so far, everythings working right.
I just need to know how to tie into this stuff... where to find the wires, etc...
kaezoo
Copper - Posts: 125
Posted: January 09, 2006 at 8:33 AM / IP Logged
I think you're confusing a factory alarm disarm output with an anti-theft system bypass.  The Audiovox is equipped with the first, but not the second.
progboy
Member - Posts: 7
Posted: January 09, 2006 at 9:00 AM / IP Logged
OK. So what do I need?
And how do I get it?
Here's what Audiovox says...
Black w/ Yellow Trace Wire: Ground Output During Start (Crank)
The Black w/ Yellow Trace wire will provide a 300 mA ground output while the starter output of the remote
start unit is active. This output can be used to activate the Crank Low/Bulb Test wire found in some GM
vehicles. This wire is also referred to as the ECM wake up wire in some vehicles.
NOTE: The outputs above are low current outputs and must be used with a relay if the circuit's requirement
is more than 300 mA.
2 Pin Transponder Control Output: (Orange Connector)
This output is intended to allow the control of a transponder bypass interface module or transponder
bypass relay. The system also allows software selections to control the way in which this output
operates, see remote start feature # 10 for setting this output.
When the unit is selected for output during the start sequence, this output will be active at the same
time Ign. 3 becomes active, and will remain active until the vehicle has started. This will be used for one
time read transponder circuits.
When the unit is selected for transponder on, this output will become active at the same time ign. 3
becomes active, and will remain active all the time the unit is operational under the control of the remote
start. When the unit is selected for continuous and the vehicle is started via the Remote Start, this
output will become active at the same time ign. 3 becomes active and will remain active until the ignition
in the vehicle goes low. This will allow the unit to be used for continuous read transponders circuits.
mo12v
Posted: January 09, 2006 at 9:06 AM / IP Logged
That is for the Operation & Connection of OPTIONAL ByPASS that you WILL need for that vehicle..........
It would be worth it to you to have a Professional Install
MO
progboy
Member - Posts: 7
Posted: January 09, 2006 at 9:30 AM / IP Logged
I called Audiovox and they told me I have to buy the bypass module like you said. They also told me that I need a databus module to unlock and lock the doors.
Does anyone know which modules  I need to buy?
Why is it worth it for me to have a Professional Install?
I already did the hard work, I just need to get over this GM BS.
Ravendarat
Platinum - Posts: 2,806
Posted: January 09, 2006 at 10:39 AM / IP Logged
Use a dei 457G module and all your worries will go out the window.
mike swanson
Copper - Posts: 290
Posted: January 09, 2006 at 11:04 AM / IP Logged
you can bypass the Key with a Resistor, but you will need a bypass kit for the locks anyways. I think you should use the crimestopper GM-SL This unit is made for your truck. I have them for 50.00= ship
I also will send you all the wiring colors you need
progboy
Member - Posts: 7
Posted: January 09, 2006 at 12:09 PM / IP Logged
Well, too late, I already paid $64 for a 457G. I hope this will work.
Let's see...
Black = ground (not under dask)
Red  = constant 12V
Gray/Black = (+) dome light
RED / White = N/A (trunk release)
BROWN / White = panic (I won't use this)
LIght Green = alarm (-) lock
Blue = alarm (-) Unlock
Violet = ODB II Plug Violet, pin 2
Blue/White = alarm ground output during start (crank)
Green = alarm door drigger input
Pink/Black = Ignition side / PK wire
Pink = Module side/PK wire
Someone once said I can use this module for heated seats. How's that?
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
