2004 GMC Envoy
05gt
Silver - Posts: 628
Posted: January 11, 2006 at 12:00 AM / IP Logged
Just to clear this up
1st IGN pink,   2nd IGN white,    1st ACC orange,   2nd ACC brown
and is that how they should be wired
Thanks in advance
kgerry
Platinum - Posts: 3,455
Posted: January 11, 2006 at 8:36 AM / IP Logged
you dont NEED the brown hooked up..... other than that, yes....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sparkie
Platinum - Posts: 2,061
Posted: January 11, 2006 at 5:09 PM / IP Logged
Actually you do require the Brown second accessory wire on those vehicles now. If not you will set a trouble code on some of these vehicles. It powers up a transmission module on these vehicles. The check engine light doesn't always come on at first, but will after a few minutes. It's not on all of them, but it is better to do it and not have it come back. I have seen quite a few already do this.
sparky
extreme1
Silver - Posts: 1,070
Posted: January 11, 2006 at 5:52 PM / IP Logged
Accually it's a secondary air something or other and it's only on the 06's so far.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
sparkie
Posted: January 11, 2006 at 6:49 PM / IP Logged
I beg to differ. I have had to fix 3 Envoys for this so far and one was a 2004 and the others were 2005's.
sparky
mo12v
Posted: January 12, 2006 at 8:23 AM / IP Logged
Some may not agree......But this is how I have hooked up since 2002.
Never had one come back...........
And I always Power the Brown wire
Constant 12 voltsRED (2)IGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
MO
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
