2004 galant, remote start
pbrooks67
Posted: January 22, 2006 at 11:29 AM / IP Logged
When the key sense wire has been bypassed the car will only start for one second and then shut down.  If the key is set in the ignition, in the off position the remote start works fine.  Is there any other wire than the blue red that needs to be interfaced?
pb67
pbrooks67
Posted: January 22, 2006 at 11:38 AM / IP Logged
How do you interface the factory trunk release wiring.  I realize that it is not a simple positive trigger system.  According to the fact sheet the system is 5wi.  What does this mean?
pb67
pbrooks67
Posted: January 22, 2006 at 11:44 AM / IP Logged
What needs to be done to interface the remote start with the keysense. I have by passed the blue/red wire and the car will only run for one second. If the key is inserted into the ignition in the off positioin the remote starter works fine. Is there another wire that needs to interfaced  for the unit to work?
pb67
cntrylvr79
Silver - Posts: 582
Posted: January 22, 2006 at 12:27 PM / IP Logged
DO you have a bypass module?  There's a chip in the plastic head of that key.  Depending on the module you get you'll have to place one of the keys to the car in the module for it to transmit the signal from the key to the key cylinder when remote started.
Cause I'm So white and nerdy...
First Class Certi-fried installer
