2005 dodge neon, alarm/keyless
gtrscort
Posted: January 30, 2006 at 1:59 PM / IP Logged
can someone tell me how to go about hooking up the alarm key less entry to the factory key less? i dont want to have to use use seaparate remotes to unarm the alarm and unlock the doors...thanks
prdjr165
Copper - Posts: 293
Posted: January 30, 2006 at 2:43 PM / IP Logged
You won't need the factory remotes after you hook-up the aftermarket alarm.It will lock/arm and unlock/dis-arm with the aftermarket remote,plus you will get much better range.Does your car have a factory alarm already?
gtrscort
Posted: January 30, 2006 at 4:39 PM / IP Logged
yeah i have a factory alarm
prdjr165
Copper - Posts: 293
Posted: January 30, 2006 at 6:31 PM / IP Logged
you have to use 2 relays with resistors.
lock is a 2700ohm resistor
unlock is a 7500ohm resistor
prdjr165
Copper - Posts: 293
Posted: January 30, 2006 at 6:38 PM / IP Logged
Relay 1 is like this:
term 85 from alarm-lock wire
term 86 to 12volt constant
term 87 to ground
term 30 to car lock/unlock wire with 2700ohm resistor
relay 2:
term 85 from alarm unlock wire
term 87 to ground
term 30 to car lock/unlock wire with 7500ohm resistor.
The resistor values would be different if the car did not have a factory alarm.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
