pioneer 12 dual voice sub
doogi0122
Member - Posts: 44
Posted: February 01, 2006 at 11:22 PM / IP Logged
hey all. i got a question. i just got a pioneer 12 " dual voice sub.my question is how do i hook it up?.do i need to get 2 amps to run it? or will the sony xplod i have be ok? any help is greatly appriciated
doogi
willdkartunes
Copper - Posts: 250
Posted: February 01, 2006 at 11:31 PM / IP Logged
What kind of Pioneer sub are you talkin about?? and what Sony Xplod amp? Be specific!
doogi0122
Member - Posts: 44
Posted: February 01, 2006 at 11:40 PM / IP Logged
its a pioneer ts-w306dvc 12" dual voice coils and a sony xplod 2/1 channel amp
doogi
jlord16
Silver - Posts: 322
Posted: February 02, 2006 at 6:36 AM / IP Logged
Is the sony going to be running the sub bridged or off one channel.  Its proberly only 4ohm stable bridged but 2ohm stable stereo.  If that is the case, run the sub off one channel with a 2ohm load, or bridge it and run an 8ohm load (will result in a power loss) or get a mono amp.
Option 1 (parallel) = 2 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
pioneer 12 dual voice sub -- posted image.
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
geepherder
Platinum - Posts: 3,668
Posted: February 02, 2006 at 1:29 PM / IP Logged
Bridge the amp, and wire the voice coils in series (assuming the sub is a dual 4 ohm voice coil).
Don't just use one channel of the amp with the voice coils in parallel, as this will not give you any more power, and will not sound as good (more THD at lower impedance levels).  Also if the signal that's input to the amp is in stereo (not mono), you may only get half the audio signal left or right.
speg80
Posted: February 06, 2006 at 9:38 PM / IP Logged
how do you tell if the signal to the amp is stereo or mono?
willdkartunes
Copper - Posts: 250
Posted: February 06, 2006 at 11:39 PM / IP Logged
There should be a switch on the side of the amp that tells you.
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
