rpm connection
waxer52
Member - Posts: 11
Posted: February 07, 2006 at 1:05 PM / IP Logged
i got a couple of diodes in work today.i'm not sure if they are good enough, they read in4004. anotherquestion is about the connection to the alternator, is it just connect to it the same as any other +wire?
waxer52
Member - Posts: 11
Posted: February 07, 2006 at 1:26 PM / IP Logged
it tells me in the manual that i need the alt connection for the autostart/turbotimer (turbotimer is built in). will these diodes be o.k for my hookup to the indicators?
Powermyster
Silver - Posts: 962
Posted: February 07, 2006 at 5:53 PM / IP Logged
use 6 amp diodes the 4 will heat too much.
whats up with the alternator..
is it not a tach connection that you need. all remote starter should be connected to a tach wire that can be got at distributor or injectors..
what exactly does the manual say to connect to   word for word
Why oh Why didn't i take the blue pill
Darren Power
dualsport
Silver - Posts: 983
Posted: February 07, 2006 at 8:17 PM / IP Logged
The 4004 diodes you have are only rated for 1A; here are some that are 6A-
6A diodes
waxer52
Member - Posts: 11
Posted: February 08, 2006 at 3:10 PM / IP Logged
the manual says that the RED / black wireshould be connected to the alternator and that it should have a voltage of 4.5v. i was talking to an installer today and he said that when you start the car this voltage should drop to 0v.
Powermyster
Silver - Posts: 962
Posted: February 08, 2006 at 6:58 PM / IP Logged
any alarm i've done needs a tach connection unless it has voltage sensing. the tach connectio can be got as discribed above..
contact louie in besecure 2000 he sells them alarms so he will know if its not standard tach
Darren Power
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
