Clifford Rsx 3.5 H3 lights conflict
JWorm
Platinum - Posts: 2,208
Posted: February 07, 2006 at 11:59 PM / IP Logged
I ran constant to the battery.
You can get (-) parking lights at the switch or at the BCM
BROWN / white switch or BCM, gray plug, pin A7
I REPEAT...WHERE IS YOUR GROUND? There are some underdash brackets that make horrible grounds because they are screwed into plastic. I would try the kick panel area.
lost01
Member - Posts: 14
Posted: February 08, 2006 at 12:20 AM / IP Logged
Oh sorry, under the plastic piece by the hood and parking brake release, there is a metal piece with 2 bolts close to the door. I grounded to the top bolt there.
