Can Digital display d-block drain bat?
groggy23
Copper - Posts: 67
Posted: February 14, 2006 at 12:10 AM / IP Logged
I have this exact type of fused digital display d-block.
http:///.com/Stinger-HPM-AGU-Fused-Digital-Distribution-Block_W0QQitemZ5850494799QQcategoryZ50550QQrdZ1QQcmdZViewItem
When its not in use it has 2 dimmed led lights that stay on even with the car completely off, trunk closed, 24/7...  Will this drain my battery any quicker or will it be almost negligable?  I haven't really had much problems with it though.
jeffchilcott
Platinum - Posts: 2,483
Posted: February 14, 2006 at 2:50 AM / IP Logged
unless you have a failing battery to start this will have such little impact on your battery you would never notice it.     Most Led lights have a draw in the Miliamp range no where near enough to effect a battery
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
oxygen65
Silver - Posts: 252
Posted: February 14, 2006 at 2:57 PM / IP Logged
you should be fine as long as you drive ur car, if you let it sit there for 2 weeks without starting it then yea it is going to drain ur battery but you wont even notice it if you drive ur car everyday
kirktcashalini
Silver - Posts: 492
Posted: February 14, 2006 at 3:49 PM / IP Logged
I had 10 LEDs at 50 mA each... soooo .5Amps on my old s-10 that were on all the time. It was more of a hot rod and DID end up sitting once for 3 weeks. Fired right up. It was a mid shelf battery too. So dont worry about LEDs if I were you. I dont worry about them myself.
groggy23
Copper - Posts: 67
Posted: February 14, 2006 at 9:36 PM / IP Logged
Ok great, thats a good sign of relief for me. Thanks everyone. :)
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
