MDF box, what kind of screws to use?
davidh_r
Copper - Posts: 59
Posted: February 15, 2006 at 2:33 PM / IP Logged
whats the minimum distance i should keep the screws from the edge of the wood (so it wont split)? Oh, im using Liquid Nails ultra quick grip construction adhesive,. Is this the best liquid nails adhesive for this application?
kfr01
Gold - Posts: 2,121
Posted: February 15, 2006 at 2:56 PM / IP Logged
Depends on the temperature and the exact brand of MDF you have.
Experiment.  Predill slightly undersized holes if you are concerned.
New Project: 2003 Pathfinder
luckydevil
Silver - Posts: 365
Posted: February 15, 2006 at 3:39 PM / IP Logged
You need to have the screw centered on the vertical board. So basically you need to be predrilling your holes ~.375" from the edge (1/2 of .75") for 3/4" MDF. Line the horizontal board up with the edge of the vertical board and predrill away.
davidh_r
Copper - Posts: 59
Posted: February 15, 2006 at 4:59 PM / IP Logged
I realize you need to drill in the middle of the vertial board, but im talking about how far away from the edge you should stay from
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
