2001 VW Beetle-door unlock
russ lund
Copper - Posts: 188
Posted: February 15, 2006 at 3:23 PM / IP Logged
I have a 2001 Beetle in my shop for a R/S.I cannot find the wire to unlock(and disarm).At the door switch there is no Yellow/lt blue and WHITE/ green.There is a yellow and if you pulse it to gnd. It will lock.After the last vehicle(mitsubishi-diamante) and this one,I need a Belt.Russ.
BigDog
kohara73
Copper - Posts: 192
Posted: February 15, 2006 at 4:55 PM / IP Logged
Are you looking inside the door, or do you just have the switch pulled out? DEI's wiring says it's inside the door. Hope this helps.
Keith
gus1
Gold - Posts: 1,013
Posted: February 15, 2006 at 5:16 PM / IP Logged
You will find the wire at the harness heading towards the latch of the door. Doorpin, lock, and unlock will all be in that same harness.
Gus
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
