impulse 990
spanoman2000
Posted: December 28, 2002 at 10:27 PM / IP Logged
i just bought an impulse 990 alarm w/ remote start. need to install in 1994 ford f-150. need instructions and wiring diagram. can anyone please help?
Platinum - Posts: 12,488
Posted: December 28, 2002 at 10:39 PM / IP Logged
Here is the wiring for th truck:
|              12V|yellow              |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|        ACCESSORY|gry/yel & blk/grn   |+  |ignition harness            |
| SECOND ACCESSORY|gray / YELLOW    18awg|+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |*1 |either kick panel *2        |
|     POWER UNLOCK|pink/green          |*1 |either kick panel *2        |
| PARKING LIGHTS +|brown               |   |lt switch or dr kick        |
|       HEADLIGHTS|RED / yellow          |+  |at switch                   |
|     DOOR TRIGGER|BLACK/ blue          |+  |driver kick panel           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|dk.GREEN/ purple     |-  |                            |
|       TACHOMETER|tan / YELLOW *3       |   |at coil                     |
|       BRAKE WIRE|lt. green           |+  |brake pedal switch          |
|     HORN TRIGGER|dk. blue            |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|red - yellow        |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blk - yel/blk   |A  |in drivers door or pkp      |
Notes:
*1 Negative trigger on the keyless-entry versions and 5-wire on all the rest.  *2 ESSENTIAL to use driver's switch when testing for switch and motor sides. The wires are much easier to access on the passenger side due to the E-brake blocking the drivers kick.      *3 Diesel tach is a WHITE/ pink and the diesel wait to start wire is BLACK/ pink (-), this wire MUST be diode isolated from the instrument cluster to keep the battery from draining 'see direct fax document #1090'. Both wires are located at the PCM or can also be located in the main harness that runs on the inside of the firewall to the left of the brake pedal.
Here is the wiring diagram for the IMP 990: Impulse 990 Wiring Diagram
cool_chick
Member - Posts: 6
Constant 12V+Yellow Ignition Switch Harness
StarterRED / Light Blue Ignition Switch Harness
IgnitionRED / Light Green Ignition Switch Harness
AccessoryGray / YELLOW Ignition Switch Harness (Blue/Green for Heat/AC)
TachTan / YELLOW Coil
Neutral Safety WireNot Grounding OEM Switch opens Starter Circuit
Brake SwitchLight Green Brake Switch
Trunk Pinn/a
Parking LightsBrown Light Switch
Head LampRED / Yellow (+) Light Switch
Hood Pinn/a
Factory Disarmn/a
Door TriggerBLACK/ Light Blue Pin Switch or Driver's Kick Panel
Door LockPink / YELLOW Passenger's Kick Panel
Door UnlockPink/Light Green Reverse Polarity use Driver's Switch to Test
Horn WireDark Blue (-) Steering Column
Windows UpLF=WHITE/ Black, RF=WHITE/ Yellow
Windows DownLF=WHITE/ Black, RF=Tan/Light Blue
spanoman2000
Posted: December 30, 2002 at 12:32 AM / IP Logged
thank you.
