98 Toyota Corolla w/black widow alarm
slonoma98
Member - Posts: 19
Posted: February 21, 2006 at 8:23 AM / IP Logged
Guys I just installaed a Black Widow 3900 alarm last night.  The alarm is supposed to lock the doors once the ignition is turned on.  However, it only does it sometime.  I make sure all the doors are closed before I turn on the ignition and it only locks the doors 1 out of maybe 4-5 tries.  Any ideas what the problem could be?  Thanks
http://www.blackwidowsecurity.com/3900.htm
Platinum - Posts: 12,488
Posted: February 21, 2006 at 8:32 AM / IP Logged
Does your keyless entry work fine ? How did you make your connections ? Solder/tape or connectors?
slonoma98
Member - Posts: 19
Posted: February 21, 2006 at 9:14 AM / IP Logged
The keyless entry work fine.  I used connectors in the install.
mo12v
Posted: February 21, 2006 at 9:52 AM / IP Logged
You did program it for that?
Programmable Ignition Controlled Lock/Unlock
MO
slonoma98
Member - Posts: 19
Posted: February 21, 2006 at 10:04 AM / IP Logged
Yes I programmed the unit for it.  I believe that the  ignition lock feature is on by default, but i re-programmed the feature again anyway.  The keyless entry works fine and the lock unlock when the ignition is turned off.  They just won't lock everytime when the ignition is turned on.   I've even tried the 1sec. lock, 3 sec. lock and 1sec. lock x 2 features and those didn't help either.
thepencil
Gold - Posts: 1,526
Posted: February 21, 2006 at 10:38 AM / IP Logged
Do you know if you got the correct ignition wire? If you did not make the correct connection to the ignition wire that might be your problem. Reading from your post it sounds like that to be the case. Your ignition wire from the alarm unit should be connected to either of the wire below.
IGNITION|BLACK / YELLOW        |+ |ignition harness            |
SECOND IGNITION|BLACK/ orange        |+ |ignition harness            |
Be careful whose advice you buy, but be patient with those who supply it.98 Toyota Corolla w/black widow alarm -- posted image.
slonoma98
Member - Posts: 19
Posted: February 21, 2006 at 10:43 AM / IP Logged
Thanks, I'll check those wires to see.  I've also noticed that the dome light supervision doesn't work, any ideas?
slonoma98
Member - Posts: 19
Posted: February 21, 2006 at 1:22 PM / IP Logged
I checked the wiring and it's on the BLACK / YELLOW...I tried the BLACK/ white with the same results.  However it seems that if I put the key to on and then off then on again and start the car, the doors lock.  I guess if I can't figure it out I'll just live with it like that.
thepencil
Gold - Posts: 1,526
Posted: February 21, 2006 at 2:28 PM / IP Logged
Also check to see if you have a good grounding point for the alarm unit. If you have a poor ground. It can also make the alarm unit behave irraticly. I would try and relocate to a different grounding point and see if there is any impovement.
another-kelly
Silver - Posts: 618
Posted: February 21, 2006 at 4:18 PM / IP Logged
try a relay for the dome supervision. i know the older black widows needed a relay 99% of the time
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
