06 Dodge Ram Diesel Remote Start problem
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: February 24, 2006 at 2:23 AM / IP Logged
Hey guys.
At work, we have been having troubles installing remote start systems in the new Ram diesels.  One of the other installers did one tonight and we found the e-brake light on, the airbag light on, and when started with a key, the engine would die after only a few seconds.  However when remote started, the engine would stay running, even after turning off the alarm control.  The customer needed to leave, so we pulled the fuses in the alarm, and everything went back to normal.  I also found out that one of the other installers did one a while ago with problems as well, but with different lights on than this one and without the starter issue.  Does anyone know of any tricks that are needed for the new Rams?  If it helps, I know he installed a Clifford alarm, a bypass module requiring a chipped key (probably a 556UW), a door lock interface, and a pulse time generator.
dfiddy
Copper - Posts: 162
Posted: February 24, 2006 at 2:37 AM / IP Logged
Make sure that you wired your accessory and 2nd start relay correctly with the right ohm resistors. I've used a PATS CHRYSLER 04+ for transponder and 2nd accessory and 2nd start. Works like a charm.Just use relays and reisitors for locks/factory security.   What type of remote starter are you installing? What are you using for transponder bypass? How many keys do you have to start the Ram? Do they all start it? Anythings else that you can tell us will help us troubleshoot it.
Steven Kephart
Posted: February 24, 2006 at 3:14 AM / IP Logged
Sorry, I wasn't the one doing the install.  The installer doing it is master certified with over 12 years experience.  He knows the Rams very well.  It just seems that the 06 has been giving us difficulty.  I know the alarm/starter is a Clifford.  I don't believe it is a two- way alarm though.  Most likely the bypass module he is using is a DEI 556UW.  He most likely used the resistors specified by Directechs.  The remote start works, so that proves the key installed in that module is coded correctly.  Plus the original key works fine when the alarm was disabled, so yes both keys start it.  It's just that the engine shuts off after a few seconds when started with the original key while the alarm is powered up.
extreme1
Silver - Posts: 1,070
Posted: February 24, 2006 at 9:24 AM / IP Logged
a. the bypass is staying powered up when the alarm is powered, trace the ground when running and see if it's active or if there's more than one item using that line, you may need a simple diode to keep things isolated.
b. the airbag/brake lights are becuase the 2nd ign/acc are getting the wrong resistance. I have found 510ohm is what is needed to get it to work properly.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Platinum - Posts: 12,488
Posted: February 24, 2006 at 9:58 AM / IP Logged
This member had the same problem with the no start issue with the key:
https://www.the12volt.com/installbay/forum_posts.asp?tid=73359&get=last
It's the bypass module still inducing a signal to the Sentry system while starting. The other error lights are as stated in the other posts..... just incorrect resistor values.
Steven Kephart
Posted: February 24, 2006 at 12:24 PM / IP Logged
Thanks a lot guys.  I really appreciate the help.  It looks like Directechs recommended a 180 ohm resistor on that starter wire.  I'll let him know to try the higher value when the customer comes back in, as well as the diode isolation.
meh66
Copper - Posts: 266
Posted: February 24, 2006 at 1:03 PM / IP Logged
How about using a CAN-SL. I have not done this vehicle yet, but I used my first GM-SL yesterday on a 2004 Chevy Impala and everything worked fine. Here is the link to that module. http://www.autoland.ca/byPassModule/byPassShowByVehicle.asp
MEH66
"Car Performance and Mobile Electronic Enthusiats"
Steven Kephart
Posted: February 24, 2006 at 10:20 PM / IP Logged
Unfortunately we can only install products Car Toys sells.
Well, the customer came back today.   It turns out the problem with the vehicle dying with the key was because the ignition (pink) wire on the bypass module was connected, and it wasn't supposed to be.   The wire list in the instructions specified that wire to be connected, but the diagram showed it as "unused", so I can see where the confusion came from.
He tried the 510 ohm resistor and that didn't get rid of the trouble lights.  I'm not sure if the problem was solved when the customer left.
wiretapper
Copper - Posts: 166
Posted: February 25, 2006 at 9:29 PM / IP Logged
[QUOTE=meh66]How about using a CAN-SL. I have not done this vehicle yet, but I used my first GM-SL yesterday on a 2004 Chevy Impala and everything worked fine. Here is the link to that module. http://www.autoland.ca/byPassModule/byPassShowByVehicle.asp[/QUOTE]
GMSL works real nice. I had two CANSL's not work properly. So much for those.
Steven Kephart
Posted: February 26, 2006 at 2:02 AM / IP Logged
So does anyone know what resistance to use to get rid of the airbag light and brake light?  We don't want to throw out miscelaneous resistances at the computer and screw something up permanently.
