Aux in wiring, new toyota head units?
yardbuzzard
Member - Posts: 7
Posted: February 24, 2006 at 5:35 PM / IP Logged
Anyone know the pin connector location or color code for the wires leading to the aux in on stock head units. As an example, Scion 06 models have aux plug-in in the console for mp3 or other devices.
I want to access the input at or near the head.
Any help would be appreciated
thanks in advance
tcss
Silver - Posts: 1,623
Posted: March 08, 2006 at 2:51 PM / IP Logged
Contact a company called Vaistech, they make a whole line of I-Pod and Aux inputs for late model Toyota products.
There is no such thing as free installation!
mad550
Copper - Posts: 201
Posted: March 08, 2006 at 3:00 PM / IP Logged
Fujitsu Ten is the manufacturer they can help have delt with them a few times and are usually more than happy to help.
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
yardbuzzard
Member - Posts: 7
Posted: March 08, 2006 at 3:39 PM / IP Logged
thanks. They do look like the ticket. I have emailed them for some info.
cheers.
kgerry
Platinum - Posts: 3,455
Posted: March 08, 2006 at 4:07 PM / IP Logged
Directed also has a new direct I-Pod integration harness for these vehicles.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
yardbuzzard
Member - Posts: 7
Posted: March 08, 2006 at 4:40 PM / IP Logged
thanks. I will email them as well.
Seems all I need is the plug to the head with an end for an aux input. Got to be someone with an end somewhere.
kgerry
Posted: March 09, 2006 at 11:10 AM / IP Logged
not quite that simple.... you need some type of data protocol to tell the OEM radio to "open that gate" and allow an aux signal thru.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
yardbuzzard
Member - Posts: 7
Posted: March 09, 2006 at 4:01 PM / IP Logged
Shucks.
I thought that since the 06 had an aux input on the console it would was simply a line in to the head. I thought the head served as the interface. Did not know there was a interface in between on the stock unit.
thanks
kgerry
Posted: March 10, 2006 at 8:25 AM / IP Logged
it may be programmed "open"                 i was thinking of the aux ports on most OEM radios that are really for a disc changer....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
