2-SVC Subs Wired to 2 Channel Amp, 2 ohms
chmodx
Posted: February 26, 2006 at 1:14 AM / IP Logged
Here's my dilemma.
I have 2 P28S4 8" RF Subs:
50-200RMS, 400W Max
4 Ohms
Pioneer GM5000T 2 Channel amp with the following specs:
125Wx2 at 4 ohms
190Wx2 at 2 Ohms
380Wx1 at 4 ohms bridged
How do I get the 190Wx2??
chmodx
Posted: February 26, 2006 at 1:15 AM / IP Logged
PS--What I should ask is, if I wire these together, as if I'm bridging them, both + together, and both - together, will that work or blow my subs?  It's a 2 ohm load, but I am attempting the 190Wx2 output my sub's specs indicate.
stevdart
Platinum - Posts: 5,816
Posted: February 26, 2006 at 1:27 AM / IP Logged
The amplifier won't be able to operate under a load condition like that.  You see in the specs that 4 ohm bridged is the lowest impedance you can bridge across two channels.  You have a classic mismatch of equipment for what you want to get out of it.  Switch to a mono (one channel) amp and load it with the 2 ohm configuration.
chmodx
Posted: February 26, 2006 at 1:33 AM / IP Logged
Hi,
Thanks for replying.  How do they say 190Wx2 then?
I ran two el cheapo Pioneer 10s off this from the bridged connectors and they ran fine.  Any idea how to get the 190Wx2?
boardinbum
Silver - Posts: 358
Posted: February 26, 2006 at 4:46 AM / IP Logged
In order to get that 190x2, you would have to run your amplifier bridged with a 2ohm load. And you amp is only capable of handling a 4ohm load [or higher] when bridged. So you could wire them with one to each channel and give them 125 watts each or go buy a new mono amp that will do 400 rms @ 2ohms then wire your subs for that.
