alarm goes off when battery connected
redshift
Member - Posts: 17
Posted: February 26, 2006 at 7:18 PM / IP Logged
Got a weird issue on a 1989 VW Jetta GLI. Installed an Audiovox APS-250, and everything works great, except for one thing. When the battery is reconnected after being disconnected, the alarm goes off instantly. I have the voltage sensing function disabled and everything is connected correctly (to my knowledge and according to the included wiring diagram).
This is a bit annoying, especially when I do a lot of work on the car, requiring me to disconnect the battery frequently.
Is this by design? Has anything seen anything like this before?
97gss
Copper - Posts: 235
Posted: February 26, 2006 at 7:35 PM / IP Logged
That's normal for most alarms.
mrcllusb
Copper - Posts: 489
Posted: February 26, 2006 at 7:40 PM / IP Logged
The only company that i know of that doesn't do that is the DEI Clifford line.If power is removed from the units,when power is returned,the alarm returns to it's original state that it was in before it lost power.
"ole blake"
gus1
Gold - Posts: 1,013
Posted: February 26, 2006 at 11:43 PM / IP Logged
Put it into valet mode before you disconnect the battery then....... that is what it is there for......
Gus
redshift
Member - Posts: 17
Posted: February 27, 2006 at 10:17 AM / IP Logged
OK cool, thanks. Didn't know that about valet mode. I figured I'd probably never use that.
I guess that's why the two hondas we have never did that, since they both have DEI boxes.
Thanks,
mrcllusb
Copper - Posts: 489
Posted: February 27, 2006 at 10:27 AM / IP Logged
Your welcome,anytime..
"ole blake"
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
