onstar audio
crdandridge
Member - Posts: 8
Posted: February 27, 2006 at 12:42 AM / IP Logged
 which pins on the 1858 does the onstar audio come in on?  I have a 2002 buick rendezvous and would like to feed it through my aux on the headunit....thanks
Hornshockey
Silver - Posts: 520
Posted: February 27, 2006 at 12:50 AM / IP Logged
I believe the onstar has it's own harness on the back of the factory radio. I know metra makes a harness that allows you to run onstar audio through a pair of rca's to an aux in on an aftermarket HU.
oh and an 02 rendezvous won't use the 1858, it's a classII data radio, use 70-2003, or use the GMOS-01, that will retain the onstar and chimes.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
crdandridge
Member - Posts: 8
Posted: February 27, 2006 at 12:53 AM / IP Logged
u sure gmos-01 will work? i thought they didn't work with radios that have the "rds" on it?
Hornshockey
Silver - Posts: 520
Posted: February 27, 2006 at 12:57 AM / IP Logged
if it's a bose system(which I think rds systems are) you can use the GMOS-04, which provides low level inputs for the factory amplifier as well as retaining all the factory features
crdandridge
Member - Posts: 8
Posted: February 27, 2006 at 1:01 AM / IP Logged
what i did was i used a metra 70-2003t harness to relocate the factory headunit to the back, i also plan on extending the  onstar plug to the back also but how can i get onstar audio with this setup?
Hornshockey
Silver - Posts: 520
Posted: February 27, 2006 at 1:06 AM / IP Logged
oh; you've already got the t-harness, there should have been a separate plug on the back of the factory radio, that's the onstar audio plug. It's a single row, 5 or 6 pins i think. There is a metra harness that allows you to do exactly what you are trying to do, but I cannot remember the specific model number. you could try Metra. You should be able to get the specific model.
Hornshockey
Silver - Posts: 520
hey; I just found it, it's 70-2006
crdandridge
Member - Posts: 8
Posted: February 27, 2006 at 1:11 AM / IP Logged
ok, so let me get this right....i've got the factory radio relocated to the back with the t-harness, i get the 70-2006 and plug it into the 3-wire factory onstar plug and use the aux-in on the headunit...am i right so far?
Hornshockey
Silver - Posts: 520
Posted: February 27, 2006 at 2:06 AM / IP Logged
you got it; then when you need to use the onstar, just switch your headunit to aux, and away you go
crdandridge
Member - Posts: 8
Posted: February 27, 2006 at 2:20 AM / IP Logged
just one more question....with this setup (t-harness) i don't know where to get a 12v constant from, there isn't one on the harness itself (just ground and accessory)...do you have any ideas where i can get it?
